Jammed window mechanism on rear slide window
GRJ319
Hi all. Brand new to this forum lark so bear with me.
Has anyone come across this problem before. The pinch latches on the rear slide window has jammed making it impossible to open the window. It's stuck fast and it will feature prominently in my call to the dealers tomorrow! Only picked it up on Friday.
It's difficult to see in the image, it's the lower latch that's jammed in the upper position.1000013506.webp
Anyhow, any advice would be appreciated.
  • Sad
It's difficult to see in the image, it's the lower latch that's jammed in the upper position.View attachment 321105
Managed to sort it out myself! I noticed the window was not aligned to the frame. I gave it a shove from the outside and the butterfly latch relocated. It works a treat now. Result!
