Can I ask you clever chaps a question or two please? If I were to replace the above said battery (like for like) and couldn’t get it coded straight away, would it throw any fault codes? And after a while would the van just accept the new battery without coding?
This is an interesting thread for me at the minute…. I have exactly the same battery as @jordanL and last week I had two or three consecutive days when my van didn’t start up as it normally does…. normally I turn the key and it fires straight up, but last week it would crank over a few times first. Is it new battery time I wondered?
When I bought my van it was two years old…. I’ve had it now for four years and not touched the battery, so assuming it was the original when I got it, that battery is now six years old.
If you replace like with like, there shouldn't be any fault codes, but the charging system will not know that a new battery has been fitted and adapt to that until it has been installed for some time.This is an interesting thread for me at the minute…. I have exactly the same battery as @jordanL and last week I had two or three consecutive days when my van didn’t start up as it normally does…. normally I turn the key and it fires straight up, but last week it would crank over a few times first. Is it new battery time I wondered?
It will work, its just that the charging strategy will not be optimalI've been wondering about the coding of it myself and wonder if it'll still work and be temperamental or not work at all?
Many thanks for your reply SirIf you replace like with like, there shouldn't be any fault codes, but the charging system will not know that a new battery has been fitted and adapt to that until it has been installed for some time.
However, if you upgrade but fitting a higher capacity battery or an AGM battery, it would be advisable to recode. Carista is a relatively cheap and worthwhile tool to have and you can use it to recode.
