Is my CTEK D250SE dead?
marco65
Hi, no lights on my unit. First the split charge light went out but solar still charging battery. Maybe 2 days later,the solar light went off so no charging of battery at all. All the connections & fuses/circuit breakers seem to be functional. The solar panels are producing current to the unit. Any way to test the CTEK unit independently. Thanks in advance!
got a few pics of the install?
and voltage readings at the terminals?
chassis to A+ terminal
chassis to PV+ terminal
chassis to 0V terminal
Pic below is me testing by isolating only a solar input, bypassing circuit breaker. Multimeter has stopped working so no readings available now but was getting something around 14v from the panel. Shouldn't I at least be getting the top light in the triangle lit? Thx!
Hi, did you resolve this issue? Mine has just done the same thing, fuses look OK. Leisure battery is dead though and will need replacing, just hoping the CTEK doesn't need replacing too
post some pics and get some meter readings. . .?
