Chas M
I now have a 12v 110Amp Leisure Battery installed in my T6 Kombi and if possible would like to use the secondary for internal LED lighting. The optimal answer is to leave it be so that it illuminates when the side door opens but not time out which makes me ask is there a relay that would enable it to switch to leisure battery source (from starter battery) rather than time out or b) Does anyone know where I can tap into the internal cabin lighting to divert the feed to the leisure battery ideally bypassing any timing relay limitation? TIA
