BlackEgle3
Hi All,
So i have a quick question.... sorry if this has already been mentioned, i've looked through the posts and threads and can't find an answer, I may have misread or missed it though.
So i had a slide rocker light, fixed. I removed this and had an electrician wire up 6x 12v LEDs to the roof, with a dimmer switch fitted. Lights work great when the side slide door is open or shut with the engine off.
My question is when i turn the engine on, i would like the option to have the lights remain on but they currently fade off, i also can't turn them on via the dimmer switch when the vehicle is in motion.
Can i turn the fade off? or do i have to add a on/off switch, instead of a dimmer? Lights are wired to the original system (main battery) but will only be in use when engine is on, so the battery does not go flat.
I carry passengers in the cab area and the lights are for them to read etc.
Any help/advice would be appreciated.
Cheers all.
Cheers all.
