I will try anything but fuse blows with no lights on. Interior lights in cab are standard all lights in rear are from control board. I still believe it interior cab light wiring or lamp is at faultIs it just standard interior lights or are your rear lights connected ? I would remove the bulbs and fit new fuse then if fuse is still ok fit the bulbs one by one to narrow your search down circuit wise
Where is the BCM and do you have wiring diagram for interior lights. I have a dead short on interior light
No but conversion was done 2 months ago. Getting a metal to metal cracking sound from dashboard area. Could have something to do with itHave you had a windscreen lately
How much work is it to remove dashboardThat does not sound good
Ok thanksI’ve not looked tbh sorry can’t help
Thanks for videoHow to access bcm:
