Instrument cluster showing wrong door open
Bigbill
Wonder if any one can help my t5.1 showing that the passenger door is open when I open my drivers door and vice Versa on the cluster is there any way of sorting it right with vag com thanks
Please post full unedited VCDS Auto-Scan.
My van did exactly this and it freaked me out at the time, mine was caused by unplugging the cluster without disconnecting the battery, a battery disconnect for a couple minutes sorted my issues
Reactions: mmi
It's controlled by the CAN gateway - byte 1 bit 0. However, would be interesting to see if the coding is messed - gateway replaced and not coded?
Let's verify your current CAN gateway coding.
Please post VCDS Auto-Scan
VCDS > Auto-Scan > Start > Save... Attach the file here.
