Indicator Problems
Custom-fit
Lost driver side inidcators, passenger side works fine.
Tried the fuse layout diagram but no fuse seems to be blown. are the sides fused separately?
do the hazards bypass indicator fuses?
I think it’s a modern day issue with most cars... or is it the ignorant lazy arsed drivers?
Do the hazards all work?
Do you get the sound but no lights?
It maybe a stork issue if hazards all work.
I’ve got the same problem, now. Was messing around with some LED sequential repeaters and accidentally fused something.. cue some smoke and I’ve lost the offside signal (front, back and side). Hazards, indicating and van locking / unlocking are all affected.
Sorted. Left it a while and then cycled the ignition. All now works.
I'm in the same boat Hazards don't work...but sounds about right on the button(which i've replaced thinking it may have been the relay).Then indicators don't work,but are alot quicker on the dash,if that makes sencse.Checked all the fuses and seem ok,even bought a Vcds lead from Ross Tech and had a nosey with that.I have changed the rear lights/side indicators to LED and it was fine.Then did the headlights(travelinlite) and they work fine,but now indicators and hazards don't!Don't really want to swap the headlights back,but it seems the only way to cure this!
Can you post your VCDS Autoscan?
Reactions: mmi
Sent from Mail for Windows 10
Code:
39460
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZHX007765 License Plate: T66PFR
Mileage: 107880km-67033mi Repair Order: 00000007
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZHX007765 Mileage: 107880km-67033miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KL HW: 04L 907 445
Component: R4 2.0l TDI H02 3802
Revision: 23002001
Coding: 00194014430401090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 015F8F2F7180A84380D-8054
15 Faults Found:
25577 - Engine Start Blocked by Immobilizer
P1570 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 107881 km
Date: 2051.01.24
Time: 16:22:28
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 19 °C
Intake air temperature: 27 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.734 V
Unlearning counter according OBD: 40
Immobilizer Snapshot 001 Byte 1: 94
Immobilizer Snapshot 001 Byte 2: FF
Immobilizer Snapshot 001 Byte 3: CA
Immobilizer Snapshot 001 Byte 4: 12
Immobilizer Snapshot 001 Byte 5: 30
Immobilizer Snapshot 001 Byte 6: 00
Immobilizer Snapshot 002 Byte 1: 00
Immobilizer Snapshot 002 Byte 2: 00
Immobilizer Snapshot 002 Byte 3: 00
Immobilizer Snapshot 002 Byte 4: 00
Immobilizer Snapshot 002 Byte 5: 00
Immobilizer Snapshot 002 Byte 6: 00
Immobilizer Snapshot 004 Byte 1: 00
Immobilizer Snapshot 004 Byte 2: 00
Immobilizer Snapshot 004 Byte 3: 00
25796 - Body Control Module (Central Electric)
U0140 00 [032] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 107881 km
Coolant temperature: 14 °C
Intake air temperature: 10 °C
Voltage terminal 30: 12.671 V
Accelerator pedal travel: raw value: 0.00 %
CAN status - engine control module: 0
Cruise Control System (CCS): status: main switch off
selected gear: Shifting process active
25797 - No Communication with Diagnostic Gateway
U0146 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 107881 km
Date: 2051.01.24
Time: 17:02:47
Coolant temperature: 13 °C
Intake air temperature: 6 °C
Voltage terminal 30: 12.062 V
25810 - No Communication with Instrument Cluster
U0155 00 [032] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 107881 km
Date: 2051.01.24
Time: 17:02:47
Intake air temperature: 18 °C
Voltage terminal 30: 12.390 V
25811 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 107881 km
Date: 2051.01.24
Time: 17:02:47
15917 - Glow Plug Cylinder 1
P066A 00 [032] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 107881 km
Date: 2051.01.24
Time: 00:13:00
Coolant temperature: 7 °C
Intake air temperature: 11 °C
Voltage terminal 30: 12.328 V
Pre-glow time: 2.5 s
Glow status: Readiness heat
Outside temperature sensor 1: B1: raw value: 7.5 °C
15919 - Glow Plug Cylinder 2
P066C 00 [032] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 107881 km
Date: 2051.01.24
Time: 00:13:00
15921 - Glow Plug Cylinder 3
P066E 00 [032] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 107881 km
Date: 2051.01.24
Time: 00:13:00
31164 - Relay for Reductant System
P20EA 00 [096] - Turn-off too soon
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 107881 km
Date: 2052.01.00
Time: 00:26:42
Intake air temperature: 3 °C
Voltage terminal 30: 11.875 V
Outside temperature sensor 1: B1: raw value: 14.5 °C
Reducing agent pump module relative press.: calculated: 0 mbar
Reducing agent fill level sensor: act. value: 0 mm
Sensor for reducing agent tank temperature: temperature: 0.0 °C
Reducing agent system pressurization release conditions-Engine running: Condition not met
Reducing agent system pressurization release conditions-Press. enabled: Condition not met
Reducing agent system pressurization release conditions-Heat. strategy: enable: Condition not met
Reducing agent system pressurization release conditions-Depressurized min. time below limit: Condition not met
Reducing agent system pressurization release conditions-Catalyst temp.reached: Condition not met
Reducing agent system pressurization release conditions-Release due to jammed valve needle: Condition not met
Reducing agent system pressurization release conditions-Rinse function finished: Condition not met
Reducing agent system pressurization release conditions-Initial filling completed: Condition not met
Reducing agent system pressurization release conditions-Release via inducement: Condition not met
Reducing agent system pressurization release conditions: 197
29345 - Control Circuit for Reductant Pump 2
P20FC 00 [032] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 107881 km
Date: 2052.01.00
Time: 00:26:43
Intake air temperature: 9 °C
Voltage terminal 30: 12.593 V
Reducing agent injector: resistance: 0.000 Ohm
Reducing agent system: current status: COSCR_timeout
Reducing agent system: current status: 6
30540 - Throttle Position Sensor (G69)
P0121 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 0 km
Date: 2000.01.00
Time: 00:00:00
Voltage terminal 30: 11.117 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Specified value: -0.01 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 100.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.27 %
Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage: 4.745 V
27202 - Sensor Reference Voltage A
P0641 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 107881 km
Date: 2051.01.24
Time: 00:13:33
Engine RPM: 50.75 /min
Voltage terminal 30: 4.031 V
Engine status: Engine start
Engine running time-Pressure BIN10 bar: 0 s
Control Module temperature: 20.2 °C
ESM_Battery_voltage-Voltage: 4.33 V
Low battery mode active-Bool type: No
ESM_Vext_raw-ESM_sensor_voltage: 3.2891 V
Starter control: terminal 50 feedback-Terminal 50 on CAN: not active
Starter control: terminal 50 feedback-Terminal 50 CAN valid: active
Starter control: terminal 50 feedback-Terminal 50 via cable: active
Starter control: terminal 50 feedback-Starter relay: active
Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: active
Starter control: terminal 50 feedback: 58
Starter control: shut-off conditions 1-Immobilizer: not active
Starter control: shut-off conditions 1-Starter shift malfunction: not active
Starter control: shut-off conditions 1-Speed: not active
Starter control: shut-off conditions 1-Drivetrain: not active
Starter control: shut-off conditions 1-RPM aborted starts: not active
Starter control: shut-off conditions 1-Engag. duration: not active
Starter control: shut-off conditions 1-Engag. duration aborted starts: not active
Starter control: shut-off conditions 1-Engag. duration panic start: not active
Starter control: shut-off conditions 1-new errors: not active
Starter control: shut-off conditions 1-manual start/error: not active
Starter control: shut-off conditions 1-ignition: not active
Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction: not active
Starter control: shut-off conditions 1-Direct start function: not active
Starter control: shut-off conditions 1-Engag. duration defrost.: not active
Starter control: shut-off conditions 1: 0
27200 - Sensor Reference Voltage B
P0651 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 107881 km
Date: 2051.01.24
Time: 00:13:33
27198 - Sensor Reference Voltage C
P0697 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 107881 km
Date: 2051.01.24
Time: 00:13:43
Voltage terminal 30: 3.390 V
ESM_Battery_voltage-Voltage: 3.88 V
27196 - Sensor Reference Voltage "D"
P06A3 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 107881 km
Date: 2051.01.24
Time: 00:13:43
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 42216000003978
Coding: 517E4098256284858A7C027CA48721E6790000
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB49D747F41EB3B69-806A
7 Faults Found:
8277 - Databus
U1121 00 [008] - Missing Message
[ACAN: mGate_Komf_1 frame timeout]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 107881 km
8279 - Databus
[ACAN: mKombi_2 frame timeout]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 8
Mileage: 107881 km
8281 - Databus
[ACAN: mKombi_3 frame timeout]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 8
Mileage: 107881 km
8291 - Databus
[ACAN: mSoll_Verbauliste_neu frame timeout]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 107881 km
8295 - Databus
[ACAN: mIdent frame timeout]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 8
Mileage: 107881 km
8298 - Databus
[ACAN: mDiagnose_1 frame timeout]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 107881 km
8329 - Databus
[ACAN: mKombi_1 frame timeout]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 8
Mileage: 107881 km
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 30071613470434
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F4D3007ED7BBFDF-802A
3 Faults Found:
332644 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 8
Mileage: 107881 km
Date: 2021.04.11
Time: 17:02:47
Voltage terminal 15: 12.60 V
Voltage terminal 30: 5.00 V
Terminal 15 status: not coded/not installed
Entprellzeit: 5000 ms
332660 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 107881 km
Date: 2021.04.11
Time: 17:02:47
Voltage terminal 30: 12.75 V
Terminal 15 status: On
117060 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 107881 km
Date: 2021.04.11
Time: 17:02:47
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 73B3D5E73B3C8AD3821-8026
1 Fault Found:
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Mileage: 107881 km
Date: 2021.04.19
Time: 11:30:23
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 215161007
Coding: E8AC393A0A23201100200974252A8C549F10710F60464D70320400230800
Shop #: WSC 35110 377 08192
VCID: 2A0D0883ACF68B1BF17-807E
Subsystem 1 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P
Component: J386__TSG_FT 003 0653
Serial number: KU0KU004081662176176
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 003 0653
Serial number: KU0KU005081662184843
Coding: 0400A0
1 Fault Found:
03430 - Terminal 30 for Turn Signals and Brake Lights
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 24
Reset counter: 223
Mileage: 107881 km
Time Indication: 0
Date: 2021.04.19
Time: 00:58:03
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag01T H08 0018
Revision: -------- Serial number: 003V3001K42L
Coding: 000000000000000000000000000000003154
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750_VN75.rod
VCID: 3A2D38C35CD63B9B817-806E
3 Faults Found:
12670208 - Databus
U1122 00 [008] - Implausible Message
[Kombi1-3 Time Out Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
12666368 - Databus
[Diagnose Time Out Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
12674816 - Databus
[VIN Time Out Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 960 S HW: 7E0 920 960 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 750B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 392F27CF59D0308388D-806C
1 Fault Found:
12605440 - Databus
U1201 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
VCID: 6889B28B727A790B273-803C
2 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 107881 km
Time Indication: 0
Date: 2021.04.11
Time: 17:26:01
00381 - Databus Instrument Cluster
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 7
Mileage: 107881 km
Time Indication: 0
Date: 2021.04.19
Time: 11:30:23
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DC8836CF64B1B317-803E
2 Faults Found:
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [009] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 65
Mileage: 107881 km
Date: 2021.04.11
Time: 17:31:49
13762816 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 055 7067
Serial number: 21071600012027
Coding: 065700003C00000041111101008000001F010EC60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E050493909EE73B2DF-807A
4 Faults Found:
0001 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 107881 km
Date: 2021.04.11
Time: 17:30:50
Voltage terminal 30: 12.7 V
6706 - Databus
[Instrument cluster: no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Mileage: 107881 km
Date: 2021.04.19
Time: 11:30:22
Network diagnosis-Status: Not available
6714 - Databus
[VIN: no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 8
Mileage: 107881 km
Date: 2021.04.19
Time: 11:30:22
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 107881 km
Date: 2021.04.11
Time: 17:30:50
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 330B1A73
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001607233121
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 7
Mileage: 107881 km
Time Indication: 0
Date: 2021.04.13
Time: 01:56:12
Address 69: Trailer
Cannot be reached
End----(Elapsed Time: 01:22, VBatt start/end: 11.2V/11.7V. VIgn 11.7V)-----
The engine is not a problem because i have a ghost and forgot to switch it off!
Wow so many faults!
Can you clear the faults in all controllers
and redo the scan?
Also check supply line to BCM as you have this fault.
011 - Open Circuit
Reactions: mmi
Hi thanks for this!New to this so how do i clear the faults and where would the supply line to the BCM be?
Pin number 13 on BCM plug B gets permanent supply which you are missing and this comes through fuse SC47 or SC16.
Reactions: mmi
Code:
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: 7E0-937-BCM-V1.clb
Control Module Part Number: 7E0 937 090 B HW: 7E0 937 090
Component and/or Version: BCM PQ25 Max4 H81 0744
Software Coding: E8AC393A0A23201100200974252A8C540F10710F60464D70320400230800
Work Shop Code: WSC 35110 377 08192
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 223
Time Indication: 0
Address 09: DTCs cleared
Wednesday,21,April,2021,21:54:45:39460
www.Ross-Tech.com
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Revision: 23002001
No fault code found.
Readiness: N/A
Coding: 01
Revision: 00001002
Coding: 0000000003
Coding: 1400B0
Coding: 0400A0
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 107881 km
Time Indication: 0
Date: 2021.04.21
Time: 10:50:32
Coding: 750B010300
Revision: B9081001
Coding: 042305
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 107881 km
Time Indication: 0
Date: 2021.04.21
Time: 10:50:37
Serial number:
Coding: 000000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 107881 km
Date: 2021.04.21
Time: 10:50:33
Voltage terminal 30: 11.7 V
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 107881 km
Date: 2021.04.21
Time: 10:50:33
Coding: 330B1A73
Address 69: Trailer
Cannot be reached
End----(Elapsed Time: 01:07, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
This what i get now after clearing...really thank's for your help on this!
So i checked the fuses today and both seem ok,contacted traven lite and they are going to send me a couple of resistors to put on.........hopeing that fixes the problem or there will be a couple of LED Headlights coming up on the for sale thread....Can't let the van stand in this sunny weather!
Obviously you have tred disconnecting the battery for a minute or so?
Reactions: mmi
