I have some questions about the ctek 250se
Mr blue
Hi all I have the ctek 250se installed and have read the Manual but still not sure
Q. If I put a internal battery charger on it as in the instructions will it charge (on hook up) the leisure battery till full and then charge the starting battery after ?
Q if I install a solar panel will it charge both batteries like above
Or just leisure battery and can I just put the panel output directly into the ctek ?
Many thanks
- if you put a EHU battery charger connected to the starter battery, then the voltage rises to 13.1 for 5s the cteck will start charging the Aux battery. . . . .
- if EHU connected to Aux battery, the ctek will not reverse charge the starter . . . (thats solar only)
- yes - with solar it will charge Aux, then when full the Starter
Many thanks
as above . . .
put the panel direct on the ctek, providing thepanel VOC is below 23v VOC
or connect a seperate solar controller to the Aux, or starter battery . .
more info here:
Dellmassive`s -- "how I Done It" -- Thread
Kit List And Stuff -- How I Done It & What I Use --
Thanks @Dellmassive I didnt know about the EHU charging part, I can use my 50w panel for the starter battery, leaving the charger to top up the leisure battery as required. Always learn something or perhaps read the bloody instructions properly :whistle:
50w might be a bit low....
It might give you a trickle charge..... but you get the idea.
200w and your cooking . . . .
Perfect.....
Thatll keep the beers cold nicely...
