Q. If I put a internal battery charger on it as in the instructions will it charge (on hook up) the leisure battery till full and then charge the starting battery after ?
- if you put a EHU battery charger connected to the starter battery, then the voltage rises to 13.1 for 5s the cteck will start charging the Aux battery. . . . .
- if EHU connected to Aux battery, the ctek will not reverse charge the starter . . . (thats solar only)
Q if I install a solar panel will it charge both batteries like above
- yes - with solar it will charge Aux, then when full the Starter
Or just leisure battery and can I just put the panel output directly into the ctek ?
Many thanks
as above . . .
put the panel direct on the ctek, providing thepanel VOC is below 23v VOC
or connect a seperate solar controller to the Aux, or starter battery . .
40-186
www.ctek.com
more info here:
Mobile Solar Panels ? . . . - How I Did It - There is loads of background to this . . . . . but for now here is a vid for you all. =] Just remember W = V*A and as a general rule a good 100W panel will give you up to 6A charge with good sun. 25w = 1.5A 50W = 3A 100w = 6A 200w = 12A 300w = 18A...
www.t6forum.com
DC-DC Charger (for Leisure battery) -- How I Done It -- ************************************************** Dellmassive`s -- "how I Done It" -- Thread ************************************************** Kit List And Stuff -- How I Done It & What I Use --...
www.t6forum.com
