The DAB aerial is in the drivers door mirror so that won't have been touched at all.. The thing on the roof is the SOS system.Markymark59, sorry just saw your post.
Regarding the DAB aerial, I believe that the receiver is now located somewhere in the dashboard. Stereo reception does not seem to have suffered due to the relocation.
I had the roof up at the weekend for the first time proper. I did notice the wiring from the solar panel appeared to be running inside, right at the rear of the pop top so guess its all rooted through the inside of the van.
Hi mate, to be honest mine has not been up overnight in the rain yet. I’ve been lucky so far and anytime with camped out with the roof up we’ve had decent weather. If I know it’s likely to rain and we’d be leaving the next day we tend to sleep with the roof down for the odd night.Hi @gjt01 - Just come across this thread, and have seen your thread also @oldgoat. @gjt01 , I was wondering if you've used yours in the rain yet, and seen any water pooling problems like oldgoat, or frame bowing down.
I am currently weighing up options between the Horizon and the Skyline Skylo, but still unsure.
Ah, ok, fair enough. Guessing you haven't noticed any issues with rain/water collecting/pooling and coming through even when the roof is down? I think if there were issues with water pooling in the gutters with the roof down, water not running off through the outlets, you'd notice and see damp patches on the canvas when you put it up.Hi mate, to be honest mine has not been up overnight in the rain yet. I’ve been lucky so far and anytime with camped out with the roof up we’ve had decent weather. If I know it’s likely to rain and we’d be leaving the next day we tend to sleep with the roof down for the odd night.
Fingers crossed if we do get caught out we don’t suffer the same issues!
I’ve not noticed any issues with pooling water.Ah, ok, fair enough. Guessing you haven't noticed any issues with rain/water collecting/pooling and coming through even when the roof is down? I think if there were issues with water pooling in the gutters with the roof down, water not running off through the outlets, you'd notice and see damp patches on the canvas when you put it up.
I've noticed the locking tie downs go through holes in the roof, and when the roof is up those holes look like they're exposed to the weather. On the VA parts store they sell 'storm bungs', have you used these? Do you have to put these in every time the roof is up?
They can creak if the canvas hasn't been folded carefully enough.Just wondering if anyone has experienced a creeking noise coming from the roof when driving? Sounds like the rubber seal or the roof itself.
I do get a bit of creaking as well. I find sometimes it's that the front and/or back tie downs might be a bit loose, so tightening those a little bit (obviously not over tightening them) reduces the creaking. Although it doesn't go away entirely.Just wondering if anyone has experienced a creeking noise coming from the roof when driving? Sounds like the rubber seal or the roof itself.
Any suggestions on best ways to fold the canvas to avoid the creaking?They can creak if the canvas hasn't been folded carefully enough.
Apart from the obvious of ensuring the canvas isn't trapped between frame and roof (front and sides), I was always told that, prior to engaging the front bolts and sliding the hatch cover into position, I should ensure the canvas looked liked a neat, flat envelope.Any suggestions on best ways to fold the canvas to avoid the creaking?
Thanks. I know what you're describing here, that's how I fold the canvas away each time on ours. There are also little tabs on the front and sides on the inside of our canvas that you can pull on to bring the canvas in a bit more when the roof is down, so it's as neat as possible before locking in the tie down bolts.Apart from the obvious of ensuring the canvas isn't trapped between frame and roof (front and sides), I was always told that, prior to engaging the front bolts and sliding the hatch cover into position, I should ensure the canvas looked liked a neat, flat envelope.
It's tricky to describe, so I can go out and get a pic later if required, but, essentially, you should aim to achieve a triangle of canvas pointing rearwards, with the canvas on each side tucked neatly above that triangle. If done correctly, you can then just press the triangle against the roof whilst sliding the hatch cover into place,
My canvas is still quite stiff, even after 3 years of use, so this does entail some vigorous canvas manipulation - both to form the triangle and especially to get the excess canvas at each side to fold above the triangle.
