No it doesnt. Its the much-maligned standard VW offering. The relay is operated by ignition live, so as supplied theres no transfer from your LB to the starter battery.
However
read 2nd post onwards...
Here's a question. I have a CTEK250SE installed and also use a Victron 75/15 MPPT controller with a 160w solar panel. During the current travel restrictions, I see my starter battery dropping sometimes down to 11.5v so leave it running for 15mins to get it back up into 12v territory every 3-4...
www.t6forum.com
You can easily make your own equivalent of the
Votronic trickle charger.
Whilst the van is stood idle the starter battery will never be higher than your solar-charged leisure battery, so you can omit the diode,
that makes it even easier to make your own lead if you dont want to buy a ready-made (& hugely overpriced) one:
Buy two
fused cig-lighter plugs. Buy/find/cadge a 10 or 20 watt half-ohm, one ohm or two ohm resistor, its not critical.
Connect a single wire from the centre of one plug to one end of the resistor.
Connect a single wire from the centre of the other plug to the other end of the resistor.
Dont connect anything to the ground or outer 'sleeve' connections, just a single wire using the fused 'tips'.
Put the resistor in a small case of some sort ensuring that it cant short.
Make sure the 'other' end isnt touching anything and plug one end into the dash socket.
Very carefully align the other plug into the rear fag socket and push it home, remember that its 'tip' is live
from the starter battery so dont let it touch anything it shouldnt.
This is only for a maintenance trickle, dont do it if your starter battery is completely flat, if you do the resistor will get very hot.
