Highline Reverse Camera
Is it a first, Anyone fitted a posh one in there T6?
These have been around for quite a while, it’s a camera paired with an interface box from another model that reads the steering angle sensor and adapts the lines to wheel input
No don’t think so as the camera feed would need to be interrupted before the headunit and a factory camera uses a tiny coax cable that would be a swine to do anything with
Just looked back through my records and the kit I was thinking of uses an aftermarket camera that doesn’t go in the large square hole the factory camera does
Think I will get one ordered next week to have a play with see what it’s like as never laid eyes on one
Theses also need calibrating using a vw tool, not sure you can rely on the steering angle 100% if retrofitted seeing as it is already off set from middle of van.
