Sunday,23,January,2022,14:16:25:38186
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 20 25 5F 61 0B
VIN: WV1ZZZ7HZGH024896 Mileage: 53670km-33348miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (2D2D2-CXGB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KB HW: 04L 907 445
Component: R4 2.0l TDI H02 4209
Revision: 23002001
Coding: 00114014434401090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KB 004005
ROD: EV_ECM20TDI03004L906056JT.rod
VCID: 77ABE0E33F44161396B-8022
VINID: 9E606AAAA1D8A9760008420918E1829EAF
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 41875000000027
Coding: 517E4098256484828A7D027FA48821D379F500
VCID: 3FDB48C357F4EE539EB-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 28061504651147
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F5C7107E275BD5D-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 T HW: 7E0 907 047 T
Component: Climatic-T5 H22 0607
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 3B233CD343ECF273B23-806E
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 194151163
Coding: B8AC30BA0A6134B193284F747EEB8E748FAC708F60CC6D60320400220840
Shop #: WSC 63024 001 1048576
VCID: 6889B39F627A89EB0F1-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 170615 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU002071551831815
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU002071551833980
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H01 0103
Serial number: 29150001426290065284
Coding: B4FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 M HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0205
Revision: -------- Serial number: 32931514602781
Coding: 30800A
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis4K 001008
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3C213FCF46E2F54BBB9-8068
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 A HW: 7E0 907 572
Component: ACC Bosch PQx H03 0110
Serial number: 13071577122209
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001004
ROD: EV_ACCBEGVW361.rod
VCID: 343117EF6EB23D0B739-8060
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 D HW: 7E0 959 655 D
Component: VW10Airbag00J 008 0016
Revision: -------- Serial number: 003PH000K0DZ
Coding: 00000000000000000000000000000000304A
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 372B20E37FC4D61356B-8062
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 L HW: 7E0 920 970 L
Component: KOMBI H05 1007
Serial number: 00000000000000
Coding: 760B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 333314F36BBC3A336A3-8066
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042307
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 C HW: 7E0 857 511 C
Component: FLA H09 0002
Revision: AA001001
Coding: 010101E200000100000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2A0D0997BC767BFBD95-807E
1 Fault Found:
15469832 - Internal Control Module Memory Check Sum Error
B2000 04 [009] - Internal System Fault
[ECU: SPI not compatible]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Mileage: 53584 km
Date: 2022.01.22
Time: 09:10:47
Voltage terminal 15: 11.40 V
Control Module temperature: -3 ∞C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1007
Serial number:
Coding: 000000
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DC9977CF6BBFB195-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H20 0241
Serial number: VWZAZ2R8720849
Coding: 065700013C00000011111101008808001F0100D6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 211FEEBBC140B8A388F-8074
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 BH HW: -----------
Component: ECE1 2022 --- 1730
Serial number: --------------------
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02737 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 52177108571261349396
End----(Elapsed Time: 01:51, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
