High Beam Assist not working
Vito Ciampa
VW T6, BiTurbo Diesel, 2000 cc, permanent 4x4, DSG
abbaglianti automatici (LED)
ciao a tutti, ieri sera mi è successa una cosa strana, il mio T6 ha gli abbaglianti automatici (led), che viaggiano sopra i 60 km / h, gli abbaglianti si accendono automaticamente, ma non si spengono più se in senso contrario uno all'altro veicolo, cosa pensi che mi sia successo? Grazie in anticipo....
Vito
hello everyone, last night a strange thing happened to me, my T6 has automatic high beams (led), which travel above 60 km / h, the high beams turn on automatically, but they do not turn off anymore if in the opposite direction one all other vehicle, what do you think happened to me? Thanks in advance....
Vito
Check and clean the sensor behind the mirror. This time of year you can get condensation on it or the inside of the screen where it looks through.
Hi my hba is showing a fault. I have managed to remove the plastic trim around the rear view mirror, but can anybody tell me how I remove the mirror from the mount on the windscreen. Thanks
Get your vehicle scanned first.
Use CARISTA, OBD11, VCDS, VCP, etc.
and post here your complete AUTOSCAN.
Reactions: mmi
Hi Robert,
this is the auto scan results
Code:
Sunday,23,January,2022,14:16:25:38186
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2  HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 20 25 5F 61 0B
VIN: WV1ZZZ7HZGH024896   Mileage: 53670km-33348miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KB    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4209
   Revision: 23002001
   Coding: 00114014434401090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KB 004005
   ROD: EV_ECM20TDI03004L906056JT.rod
   VCID: 77ABE0E33F44161396B-8022
   VINID: 9E606AAAA1D8A9760008420918E1829EAF
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 41875000000027
   Coding: 517E4098256484828A7D027FA48821D379F500
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3FDB48C357F4EE539EB-806A
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 28061504651147
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F5C7107E275BD5D-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 T    HW: 7E0 907 047 T
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 3B233CD343ECF273B23-806E
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 194151163
   Coding: B8AC30BA0A6134B193284F747EEB8E748FAC708F60CC6D60320400220840
   Shop #: WSC 63024 001 1048576
   VCID: 6889B39F627A89EB0F1-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 170615 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU002071551831815
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU002071551833980
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 5 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 6 - Part No: 7E1 951 172
   Coding: 000000
   Subsystem 7 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H01 0103
   Serial number: 29150001426290065284
   Coding: B4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 M    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0205
   Revision: --------    Serial number: 32931514602781
   Coding: 30800A
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K 001008
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 3C213FCF46E2F54BBB9-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 A    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0110
   Serial number: 13071577122209
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001004
   ROD: EV_ACCBEGVW361.rod
   VCID: 343117EF6EB23D0B739-8060
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00J 008 0016
   Revision: --------    Serial number: 003PH000K0DZ
   Coding: 00000000000000000000000000000000304A
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 372B20E37FC4D61356B-8062
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1007
   Serial number: 00000000000000
   Coding: 760B010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 333314F36BBC3A336A3-8066
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042307
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 7E0 857 511 C    HW: 7E0 857 511 C
   Component: FLA           H09 0002
   Revision: AA001001
   Coding: 010101E200000100000000
   ASAM Dataset: EV_HighBeamAssisAU316 001004
   ROD: EV_HighBeamAssisAU316.rod
   VCID: 2A0D0997BC767BFBD95-807E
1 Fault Found:
15469832 - Internal Control Module Memory Check Sum Error
          B2000 04 [009] - Internal System Fault
          [ECU: SPI not compatible]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Mileage: 53584 km
                    Date: 2022.01.22
                    Time: 09:10:47
                    Voltage terminal 15: 11.40 V
                    Control Module temperature: -3 ∞C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 1007
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8DC9977CF6BBFB195-803E
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
   Component: MU-S-ND-ER    H20 0241
   Serial number: VWZAZ2R8720849
   Coding: 065700013C00000011111101008808001F0100D6002001004F
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 211FEEBBC140B8A388F-8074
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 BH    HW: -----------
   Component: ECE1 2022  --- 1730
   Serial number: --------------------
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A73
   Shop #: WSC 02737 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 52177108571261349396
End----(Elapsed Time: 01:51, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Was your HBA retrofitted or factory supplied?
Reactions: mmi
You could try flashing it with VCP or ODIS but I am afraid it needs to be replaced anyway.
Have a look below.
Reactions: mmi
Hi can anyone explain what @Robert means by flashing the unit, thanks
Downloading/reprogramming/reloading the software into the HBA module - as the fault code suggests the software in there is corrupted.
What would I need to go about doing this and is there a guide on how to do this?
It would happen via OBDII-socket with a proper tool - VCPSystem is a third party tool, ODIS is the VW tool.
Of course, the software package "7E0 857 511 C" is needed - could be obtained (if available at all) from
Anyways, I'm afraid it's not cost/time efficient to try to do this by yourself unless you have the tools already.
