Pete j.c
Any of you guys fitted this bracket part number 98655z156 or the very similar bracket part number 98655z147 to a fiamma f43. I am after the dimensions from the centre of the rear bracket to the shut line for the tailgate on a swb t6. My problem is in the instructions for this bracket it shows 2250mm from the centre of front bracket to the centre of rear bracket it doesn't give any dimensions of were to place the brackets. If I put the rear bracket any closer than 400mm to the tailgate shut line the bracket then starts to overlap the rain gutter on the van roof. I can't seem to maintain that 2250 dimension as the rear bracket needs a go further back. I have a Remio rail and pop top if that makes any difference. Thank you in advance.
