Good evening,
I have returned a converted van to (hopefully) original spec but am halving issues with the last few pieces.
1) I am getting faults - engine no coms with steering column control module. I have replaced the clock spring - do I need one with a steering control module and how can I tell if I have a clockspring with one?
2) ABS received scl”_acc_Anhalteweg_error - any ideas?
3) air con - local data bus 2 electrical malfunction
4) window regulators 3 faults I need to sort basic settings and reset.
5) Auto distance 5 faults - I need to program / reset
6) CAN gateway Fault in steering wheel - has been working but has now power to either controls or Horn.
7) telematics fault with LTE antenna 2 - which antenna is this?
I will post the full scan as soon as I can get the transfer to work, but I summarised it as I do not want to bore every one
Help most definitely appreciated I am beginning to run out of ideas.
John
John
