Alpine Halo 905 with Alpine APF-X303VW
Virtualmeuk
Hi Folks,
I have installed a new head unit but for the life of me I can't get the steering wheel mute button to work. I have the alpine can bus module but it doesn't seem to allow me to activate it or do anything to make it work.
Anyone have any ideas. I have vcds as well but can't find anyway of activating it in there either.
Also have a couple of strange issues when I scan the van.
I get the following:-
Any ideas welcome
2 Faults Found:
10486016 - Control module
B2001 00 [00001001] - Incorrect software version
[BAP: Steuerger‰t falsche Softwareversion]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 9
Mileage: 57414 km
Date: 2026.03.23.
Time: 04:48:36
13654544 - Databus
U1121 00 [00001000] - Missing Message
[Steuerger‰t f¸r Telefon keine Kommunikation]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 44
Reset counter: 75
Mileage: 58741 km
Date: 2026.06.01.
Time: 00:02:42
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042305
Shop #: WSC 43178 002 104857
VCID: 6889B64E22710F2A26B-803C
1 Fault Found:
03158 - Control Module for Information Electronics 1 (J794)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 9
Mileage: 57414 km
Time Indication: 0
Date: 2020.08.13.
Time: 04:48:41
VCDS is basically just showing you do not have the original head unit in.
The interface is alpine’s newer interface which is around 3 years old, and it does its best to work with all T5/T6 , Polo, Golf, Passat etc basically the range of Vw vehicles, so occasionally as it’s a universal interface a feature may not work the same as factory.
You could try unplugging the interface for secs to see if it programs itself to the ‘Can’
That’s good to know about the Vcds scan and all of the other buttons work it’s just the mute that doesn’t. I’m happy to live with it if it can’t be made to work but it niggles me 🙄
I’m not sure whether it matters but mine is an early one so my steering wheel controls are simpler than the later ones. I’m guessing it’s not something that can be coded with VCDS
