Hi all,
I need a little help with my first fix wiring so I've jotted some stuff down on the below sketch.
First off, are my cable sizes correct that I have shown? I think they are but best to double check. no cable run will be long than 3m and I've checked for Voltage Drop.
I currently have a 105ah AGM under my seat which will be removed and replaced with a Renogy 300ah. I'll reconnect the existing DC-DC and MPPT to new battery.
I'll then wire in 50mm cable c/w a 300A fuse to my Renogy 2000w Inverter.
I'll then wire from the 300ah LB to a 6 way fuse box in (CABLE SIZE UNKNOWN) and fuse with (UNKNOWN)
From there its 4mm to the fridge, 1mm to USB Ports, 1mm to Water Pump and 1mm to existing spot Lights - All these fused at the fuse box
It all might be massively wrong but you told me to have a go myself ha ha
. I'm sure I've missed something important (I do need an isolator somewhere actually)
