I do, but didn't know that particular wheeze.Do you not have the lock/unlock button on the drivers door?
Use the key in the door?How can the alarm be disabled on a car ferry and still keep the car locked when expected to leave the vehicle unatended?
That's exactly what I do. If I'm in the van I'll only ever use the sliding door and opening that only unlocks that door so it's easy to lock it again from the inside.When all the doors are locked from the inside just open the sliding door from inside all the other doors stay locked and if you need that locked after just push the slidey thing that popped up when you opened it back down
If you want the rest open in the morning open as normal on the fob
I could not remember if it even had a key hole so I have just trapped across the lawn to have a look! UUrrr.Use the key in the door?
I've done that the past few times.
One only drivers side! Ahhh that it then, no longer have to look the other way and pretend it belongs to someone else or just one of many thank you CAB . Honestly feel such a plonker! I get fed up looking through the handbook with all it referrals to another page or safety asides instead of just answering the question so become a little distracted at times and start reading about some other feature that I may not have been aware of.I could not remember if it even had a key hole so I have just trapped across the lawn to have a look! UUrrr.One only drivers side! Ahhh that it then, no longer have to look the other way and pretend it belongs to someone else or just one of many thank you CAB .
You double click the lock button on the fob, locks doors but turns off motion sensorsHow can the alarm be disabled on a car ferry and still keep the car locked when expected to leave the vehicle unatended?
That is what I originally thought but their appears to be some debate about that. Some one suggested that it just prevents the deadlock from activating hence my question bourne out of confusion.You double click the lock button on the fob, locks doors but turns off motion sensors
If I click once on the fob, the alarm tends to go off if we have pop top raised, when I double click lock on fob, I’ve never had alarm go off,, so assuming it disables internal sensors as well (6.1)I believe that just locks the van without the deadlocks. The button on the Bi pillar disables the internal sensors.
And the dead lockingYou double click the lock button on the fob, locks doors but turns off motion sensors
Lock the van from inside on that switchI do, but didn't know that particular wheeze.
Yes, but hopefully you would either be inside the van, parked on a ferry or fairly close by if you had left the pop top up, in our case we have an immobiliser so van won’t start even if thief had our van keys.And the dead locking
Excellent clear post showing what happens when locking the T6 and T6.1 shows the differences and how it may be assumed both versions are the same when they are not. Instructions for preventing alarms on ferries are model specific. Thank you @roadtripper !This is an area that the 6 and 6.1 differ, I'll try and summarise to the best of my knowledge.
4 things happen when you lock the door "normally"
If you lock the van with key or remote (single):
- The door locks engage
- The deadlocks engage to prevent opening the doors from the handles ("SAFELOCK")
- The alarm ultrasonic monitoring engages
- The alarm door switch monitoring engages
All 4 happen
If you lock the van with key or remote (double like a mouse clock):
On a 6 - 1 and 4 happen, many also have a door switch you can press as you lock up to trigger the same behaviour
On a 6.1 - 1, 3 and 4 happen (you have to disable 3 on the head unit menu each time)
If you lock the van with the drivers door switch (or any equivalent like the factory fit B pillar or DIY add on)
Only 1 happens
I don't believe there is any way of leaving the van physically locked without also the basic alarm door switch on as well. I don't think (in at least the UK) there is a default/tilt/vibration alarm option, but couldn't say for certain.
The sliding door trick doesn't work as well on a 6.1 (at least my Caravelle) as the 6.1 doors don't have a physical lock/unlock button so you can easily get accidentally locked out as it will autolock on close (ask me how I know...)
For camping the interior drivers door switch is the best method, which is why adding additional rear cabin ones is a popular option. I'd love to add one to the Caravelle but getting into the door trim and then all the side trim looks like a bit of a mission.
Welcome, I can only absolutely vouch for the behaviour of my 6.1 so if there are errors let me know and I'll edit the post.Excellent clear post showing what happens when locking the T6 and T6.1 shows the differences and how it may be assumed both versions are the same when they are not. Instructions for preventing alarms on ferries are model specific. Thank you @roadtripper !
I will have to experiment a bit later on. I was unsure about the exact function for hidden switch inside the drivers door now it has been explained thank you.Welcome, I can only absolutely vouch for the behaviour of my 6.1 so if there are errors let me know and I'll edit the post.
Oooh, this isn't how my 6.1 (converted Kombi) works. If you lock from the inside (with the switch on the driver's door panel) and then exit via the slider, it doesn't auto-lock on shutting the slider......... or have I misunderstood the point you were making?The sliding door trick doesn't work as well on a 6.1 (at least my Caravelle) as the 6.1 doors don't have a physical lock/unlock button so you can easily get accidentally locked out as it will autolock on close (ask me how I know...)
If you don't have swivels (I don't in the Caravelle) then reaching the driver's door button is a bit of a mission if you've arranged the rear of it for sleeping.I just press the lock button on the door when I'm inside. It locks and doesn't set of the alarm. If I need to go outside I press it again to lock it when I return. Why mess about with keys and fobs. Is this something like a freemason meeting where I'm missing something???
No you have the point, I'm aware there is an amount of evidence that the sliders in a 6.1 behave a bit differently if the base van was built expecting passengers in the back (Caravelle/Shuttle/California/Kombi) or Cargo. From what I can gather vans built as Cargo variants may not have the emergency crash clutches in the doors that physically connect the Bowden cables in an emergency (the 6.1 slider is wholly electric normally for increased security)Oooh, this isn't how my 6.1 (converted Kombi) works. If you lock from the inside (with the switch on the driver's door panel) and then exit via the slider, it doesn't auto-lock on shutting the slider......... or have I misunderstood the point you were making?![]()
