Can’t really see what it is but it’s either a press fit or screw fit.
Personally I’d try light force with a forked trim tool under both heads and if no movement try gripping both heads and unscrewing like a nut and bolt.
as @DXX said, they look like press on caps, you can try a pair of grips on each cap, pull apart and twist at the same time and see if one end will work its way off.
