HELP! P010100 - Mass or Volume Air Flow Sensor "A" Circuit Range/Performance issue [RESOLVED]
NicolasH
I'm having an issue with our 2016 T6 T28 102 camper van (87k). We went away just after Easter and the EML light came on. Using Carista I found these faults:
P010100 - Mass or Volume Air Flow Sensor "A" Circuit Range/Performance.
U100800 - Data Bus On Board Diagnostic Interface: Check DTC memory.
I reset the faults and carried on, but the van felt sluggish and the MPG was around 29MPG - it is usually late 30's.
Since returning, I have replaced the Mass Air Flow Sensor with an identical Bosch unit and the air filter (the original wasn't too dirty but I replaced it with a Bosch).
The van now drives as expected and the MPG has improved. The EML is off but I'm still getting the two fault codes (I did reset these after replacing the MAF.
This is what Carista is reporting:
Freeze frame :
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Odometer reading: 87807.8 miles
Engine rpm: 1997.5 RPM
Normed load value: 0 %
Vehicle speed: 53.4 mph
Coolant temperature: 91 °C
Intake air temperature: 27 °C
Ambient air pressure: 14.65 PSI
Voltage terminal 30: 13.98 V
Freeze frame :
Priority: 2
Odometer reading: 87802.2 miles
Engine rpm: 1795 RPM
Normed load value: 59.2 %
Vehicle speed: 7.5 mph
Coolant temperature: 16 °C
Intake air temperature: 14 °C
Voltage terminal 30: 14.02 V
Can anyone help and advise what I should do next?
FYI, the van isn't a daily driver and we only use it to go away in, or at the weekends.
Thanks.
Nick
Would be helpful to know exactly which engine - the engine code on configuration sticker under dash by steering column.
Meanwhile for an engine 102 without AdBlue
Thanks for replying @mmi The engine is a Euro 5, CAAB 75KW
@mmi I've just checked and I think my intercooler is leaking oil as well. Would that cause the P010100 error?
Yes, most likely.
The fault code explanation is actually
P0101 00 - Mass Air Flow Sensor (G70) - Implausible Signal​
thus air flow seen by sensor deviates iwhat ECU is expecting - because of air leak
The oil seen is residual from crankcase ventilation. The crankcase is vented into turbo input and therefrom into intercooler along pressurised air. It's normal, and actually very small amount of oil. The oil just leaves stains, the leaking air doesn't.
Yes, most likely.
Thank you so much. I really appreciate your expertise.
Do you, or anyone else, know if it is straightforward to change the intercooler? I’ve taken the bumper off a couple of times before to fit THQ LED headlights.
Perhaps some help here -
That's a great start - thank you.
If you could do a smoke test at the air filter, all the way to the inlet manifold, you could pin point any boost pressure leaks.
just a thought.
@mmi You are a LEGEND!
The old intercooler had corroded with two of the retaining straps rusted away. You can see where it was leaking. I fitted a new intercooler today (a genuine VW one, from eBay which I got for a bit of a bargain at only £96.18 brand new). The van drives much better, with improved MPG (late 30's). I've scanned the van again using Carista and there are no errors.
Thank you so much for your help.
Fitting the intercooler is straightforward. Remove the bumper, then remove the long, narrow plastic bracket followed by two bolts that hold the intercooler in place. Unclip the two intercooler hoses and remove. I did also swing the coolant expansion bottle out of the way to gain some access, and that was easy too. I've attached some photos in case it can help someone in the future.
IMG_7839.webpIMG_7853.webpIMG_7852.webpIMG_7849.webpIMG_7847.webpIMG_7842.webpIMG_7841.webp
Google Translate doesn’t do Romanian, can you please post in English?
