This afternoon I could hear the van making a few strange noises from the engine bay. I was checking this out and noticed that when I had a tow bar fitted the fitter had connected directly to the battery negative.
I remember reading nothing should be connected to this so decided to find an alternative point (with a mulitmeter).
I chose to use a bolt near to the lower left of the battery as that had a good ground.
I took the bolt out but when I tried to put it back in there was no way it will go back. The threaded component was not now in line with the hole and I cant pull the bracket behind the hole enough to get the bolt back in.
I am guessing that the van is ok to drive in the short term but will need to got the bolt back somehow so looking for suggestions.
