Trying to remove flywheel on '17 204hk 7 speed DSG 4Motion.
TorArneH
Hello.
I'm trying to replace my flywheel, an I cant seem to find all the bilts that secures the gearbox to the engine. When i pry lightly in the flywheel drain hole, the gearbox seems to bind between the engine and transfer case. Do I have to remove the transfercase to access the last bolt?
I have started to remove the transfer case, but I'm hoping there is som tips that I can use to free the gearbox.
Hello.
Hi I am having the same issue very tight to remove, can only imagine it is tight on a dowel, how have you gone on with yours? what did you find? thanks
