Help need flywheel won’t fit
Neil272
Hi all I need some help.
I purchased a Volkswagen T6 2018 engine code CXHA the van came with the engine and gearbox for me to put back together but no flywheel r clutch when I ordered the flywheel and clutch pack from TPS but when I bolt it up the engine will not turn because the flywheel is getting caught in the Bell housing .
I have provided some pictures of the gearbox help would be much appreciated . Thank Neil
Did you order with the VIN / reg number, if so maybe the engine / gearbox is not as built?
Yes I used both when ordering it . The death stamp on the gearbox corresponds with the year the van was made it fits onto the engine perfect and all the bolts r perfect I can’t work it out
