Evening all, i've changed my mib std2 pq+/nav to a Alpine halo 9 ilx f903d.
I've got the following fault codes now.
Any advice on what these are and how to reset, code them out please?
Code:
Thursday,16,April,2026,19:30:40:59141
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4701.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZKH064652 License Plate: CX19NMF
Mileage: 95792 Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 13 15 17 18 19 25 5F 61 6D 78
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
0D-Slide Door, Left -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
5F-Information Electr. -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CXFA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 MB HW: 04L 907 445
Component: R4 2.0l TDI H02 6431
Revision: 23002001
Coding: 0025401C432401080000
Shop #: WSC 00012 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056MB 004004
ROD: EV_ECM20TDI03004L906056MB.rod
VCID: 79AFEB3BF9572292C9D-802C
VINID: 9E60AAAAA1D8A9B60018418508749ECF01
No fault code found.
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5303
Revision: 00H11V01 CVN: D865F555
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021.rod
VCID: 3D273F2BADFFDEB2A55-8068
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 63348000000502
Coding: 347E4098656884822C7B027BA68421D379F700
VCID: 3FDB4523A7F3CCA2B79-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 14052113470650
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F827E07905AAFCF-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 AB HW: 7E0 907 040 AB
Component: ClimatronicT5 H04 0613
Revision: 00001K04
Coding: 0000000103
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis_VN75.rod
VCID: 6393A9536BDBC842F31-8036
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serial number: BHB-0010412180015241
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 326180281
Coding: B8DE793A0A61340393288F646CEB8EF58D84698960CC6960330400BF0840
Shop #: WSC 01211 210 01254
VCID: 2C01026F4605473A02B-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 261118 05 50 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0653
Serial number: KU0KU027111883310906
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 004 0653
Serial number: KU0KU012111883162335
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
Coding: 000000
Subsystem 6 - Part No: 7E1 951 171
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39170003041090028034
Coding: B00000
1 Fault Found:
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 154166 km
Time Indication: 0
Date: 2017.14.18
Time: 17:39:50
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
VCID: 3039161F662D23DA3E3-8064
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231831203314
Coding: 308908
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BFD31BA1276AD271D-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 0312180442A177 Dataset Number: 7E0114v____ 0009
Coding: 00005000FE1779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 3635200788C90DEA64F-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 K HW: 7E0 959 655 K
Component: VW10Airbag01S 010 0018
Revision: -------- Serial number: 003EM0025SJ7 Dataset Number: 7E0003V____ 0909
Coding: 000000000000000000000000000000003153
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3E253827A0F9C5AABCF-806A
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB405F5IGVANGI/
Crash sensor for side airbag: passenger side:
Serial number: 3505ZRB404P5IG7GC1CY
Address 17: Instruments
Cannot be reached
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 A HW: 7E0 963 273 A
Component: STH-T5GP2 003 0009
Coding: 4101
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B030173438B40020B1-807E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 042307
VCID: 6889BE7F927DAB1A263-803C
1 Fault Found:
03158 - Control Module for Information Electronics 1 (J794)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 154166 km
Time Indication: 0
Date: 2017.14.18
Time: 17:22:26
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H02 2030
Serial number:
Coding: 000002
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8DC4778CF1990A307-803E
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 D
Component: Batt.regelung H82 0762
Coding: 030B1A73
Shop #: WSC 80093 222 69422
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 7588570100181130139F
Address 6D: Trunk Elect. (J605) Labels:| 7N0-959-107.clb
Part No SW: 7E0 959 107 A HW: 7E0 959 107
Component: HDSG-Modul H02 0653
Revision: 31002002 Serial number: 314801907 Dataset Number: 7E0771V____ 0007
Coding: 19730D4002
ASAM Dataset: EV_HDSGVN46T 203001
ROD: EV_HDSGVN46T.rod
VCID: 2C01026F4685473A02B-8078
Address 78: Slide Door, Right Labels: Redir Fail!
End----------(Elapsed Time: 02:12, VBatt start/end: 13.7V/14.0V)-----------
------------------------------2 Faults Found-------------------------------
