Gateway control module
Coly
I have have multiple can bus problems and I have remove the radio unit
to get at infotainment can bus.
The signal on both the can bus high and low have a lot of overshoot so I
disconnected the battery.
With no power there is a voltage of 1.2 volts across the can bus high
and low which makes it impossible to read the resistance.
If I put a 150 ohm resistor across the high and low the voltage goes to
zero.
I am guessing i have a bad connection with moisture.
Would you agree so far?
The problem I have now is to locate the gateway control module?
Is it part of the Body Control Module on the T6 Transporter?
Below is one of the VCDS output.
Be kind as this is my first time i have used a VCDS
Thanks for any help
Tuesday,08,July,2025,18:41:06:54339
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.1.2 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250604 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZGH108107 License Plate: ML16HXX
Mileage: 84600 Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 09 10 15 17 19 25 5F 61
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAAB) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GE HW: 03L 907 309 L
Component: R4 2.0l TDI H38 9977
Revision: 22H38--- Serial number: 00000000000000 CVN: D8AF5855
Coding: 01114010230401080000
Shop #: WSC 01923 004 1048576
ASAM Dataset: EV_ECM20TDI01103L906019GE 004005
ROD: EV_ECM20TDI01103L906019GD_003.rod
VCID: 74B6025D4E366B9A9B1-8020
VINID: 9E606AAAA1D8A976010080401C7C5E9AFE
1 Fault Found:
13811 - Exhaust Gas Temperature Sensor; B1 S3
P242B 00 [01100101] - Range/Performance
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 136078 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 16 °C
Intake air temperature: 18 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 11.440 V
Unlearning counter according OBD: 40
Exhaust gas temperature sensor 1: 18.6 °C
Exhaust gas temperature sensor 2: 20.0 °C
Exhaust gas temperature sensor 3: 85.6 °C
Exhaust gas temperature sensor 4: 20.0 °C
Shut-off timer: last engine shut-off time: 32799 s
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 40406000000298
Coding: 867E40982562848661760276A48921E6390000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDC9D7137F0F8C2B63-806A
2 Faults Found:
0072 - Rear Left Wheel Speed Sensor
C101C 01 [00001000] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 136038 km
Date: 2106.14.19
Time: 14:06:43
0088 - Rear Right Wheel Speed Sensor
C101D 01 [00001000] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 136038 km
Date: 2106.14.19
Time: 14:06:43
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 18011613470769
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA22075707A31CAFD5-802A
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 043160599
Coding: E0A4303A0A2120B1002009742C2B8C508F20708F60464D60320400220800
Shop #: WSC 02737 534 989383
VCID: 688E662D027E9F7A279-803C
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels:
7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU015021660463600
Coding: 1400B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels:
7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU004021660353555
Coding: 0400A0
1 Fault Found:
01758 - Bulbs for Brake Lamps
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 249
Mileage: 136038 km
Time Indication: 0
Date: 2042.14.19
Time: 14:07:37
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 R HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0210
Revision: -------- Serial number: 32931533002849
Coding: 10800A
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_VW75XParkAssis4K 001012
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 41D89B8941048E32C07-8014
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 D HW: 7E0 959 655 D
Component: VW10Airbag00J 008 0016
Revision: -------- Serial number: 003PH002KJMM Dataset Number:
7E0003V____ 0737
Coding: 00000000000000000000000000000000304A
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 372CF5511FC0C0827E3-8062
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042305
1 Fault Found:
01336 - Company Data Bus for Comfort System
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 214
Mileage: 135929 km
Time Indication: 0
Date: 2042.14.15
Time: 20:02:12
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1007
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8A1C251CF2AD6A31D-803E
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02739 790 12345
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 53025102431261421308
End----------(Elapsed Time: 01:10, VBatt start/end: 12.3V/12.3V)-----------
------------------------------5 Faults Found-------------------------------
Yes the can gateway is integral to the BCM on a T6 (2015-2019) and it is a separate module fitted behind the cluster on a T6.1 (2019-2025)
The only module missing on your scan is 17 the instrument cluster, have you checked CAN and power going to the blue plug in the rear of it ?
*edit
Im of course assuming the stereo has been replaced with aftermarket and thats why its not showing otherwise they are both missing
The radio is factory supplied startline L56VW2.
I have almost got the BCM out but struggling with the connectors.
Thanks for confirming BCM and gateway is the same module.
I have yet to take out Instrument Cluster. Does it share the same can bus as Infotainment?
Thanks for your help it is much appreciated
Thank you for the information Pauly.
I have had out the head unit(radio), instrument cluster and BCM.
I have check the signal on an oscilloscope on head unit and there is ringing on transition but they are there.
I have checked continuity for both the can bus Infotainment and can bus dash from BCM and they are both good.
However both can buses appear open circuit between high and low. There is no 60 ohms. Should there be?
There is 65 ohms on ECU between can high and low.
I suspect the BCM which is a 7E0 937 090. Is this a reasonable assumption?
What is the best way forward if I suspect the BCM?
Any help would be much appreciated
its 120ohm at each end for CAN termination.
that means the 60ohms with the two 120ohms in parrallel.
you need to test with no can data, so everything powered down and test with multimeter - DC resistance.
the T6 BCM is the start on the CAN with internal 120Ohm but im not sure what module has the other end 120 Ohm-
ringing data is normally a sign of an unterminated data line.
Thanks for replying.
I tested with the battery disconnected. The ECU is good at 65 ohms but both the 'dash can' and 'Infotainment can' are open circuit.
I have watch YouTube videos which state that not all CAN buses are tterminated with 120 ohms. These are called star and ring.
Are either of these CANs non terminated.
The alternative is I might have started with a single fault that has caused further faults.
id start by doing a new scan.
to see what you have now.
clear down all those old faults and start a fresh.
Hello, do you have a solution for the multi error problem? I have same problems
