Going From 3 Seater Unit In Rear To 2+1 Seat Unit In 18 Plate T6
ady1966
At the moment I have a 3 seat single unit in the back of my transporter highline. There is only the central anchor point in the middle. Is it possible to swap 3 seater unit for a 2+1 seater unit ? Any help appreciated.
Yes you just need to add the additional fixing points bolted down through the floor
It will require dtrengthening plates underneath and the fuel tank needs to be dropped to access that area so not an easy diy job
If your meaning your bench seat is at the very rear ,i.e at the rear wheel arches then a don't think this will work as the 2+1 won't clear the arches am sure as I tried this in my shuttle but if you are talking about round the area of your sliding doors then you can but will need to fallow Pauly's instructions to do so
Hi Pauly
Are there any companies that will do a seat swap or will I have to sell the original seat separately ? Is this a costly business fitting the floor fixings ?
Thanks for your help....
Ady
Hi Pauly
Ady
If you’re happy to drive over to Oxford for a day, then @VWVC specialises in retrofits such as this.
