Getting Cables Past The B Pillar
Hi Currently trying to get my charging cable 10mm2 and ignition feed past the B pillar to the rear of the van where the leisure battey/CTEK will be fitted. I've had a poke around, but can't seem to find a way through. I could just come onto the panels and run the cables they will be hidden by units. Anyone had experience of routing cable ( in conduit) through that pillar?
There is a way through to the bottom of the pillar. There’s a hole to feed it through to run behind the panels.
Yep, no problem got them through thanks so much! Note to self don't put the final insulation in till you've run the cables!
Go from the dash up the A pillar into the channel through the channel and there are several holes along the route to bring it down after the B or the C ( inbetween windows ) .
