Gateway 19 Security Code Help
tintim
120,000 miles and still going
I'm trying to access gateway 19 adaptations
I have two quoted security codes available but both don't appear to work and I get locked out.
Could someone with either VCDS, Carista or ODBEleven check the codes they use for gateway and help me. Its probably something I am doing wrong. Thanks
Bah - I'm clutching at straws then. Was hoping the security code would unlock the adaptation for min voltage for start stop. Seen some info re: increasing the min voltage disables start/stop. I just want to check if mine has been set or not / or if this setting was available.
Probably doesn't apply to T6 and/or Euro5 variant.
Volkswagen – Disable automatic start-stop system – VIDEGRO Consulting Blog
Thanks for checking though... I can rule this out now.
Have a look at @Dellmassive post here Stop/start Doing Your Head In? Disabling It - How We Done It -
The voltage method doesn’t work, The temperature method I posted does
here: Override Start Stop System
Thanks @Loz @Deaky I have read those threads with interest and I was hoping this might unlock the reasons why my SS doesn't work. Strangely the last known time it worked is when I heavy braked at the lights. Perhaps it is something to do with the recuperation or battery, I've had the battery at 14v so I would have thought this eliminated the latter.
Brake pressure also counts, try pressing harder on the brakes with the steering straight on your way back from your next trip out.
