Front Suspension Shudder
Fluff34567
Swiss member
Van is new to me and I know its had new struts on the front.. Factory Dynamic suspension so its 20mm lower than standard.
I find when going over dropped curbs with both front wheels at same time the suspension feels as if it shudders and I get quite a bit of movement in the steering wheel.
I had something similar in a normal car and it was worn trailing arm rubber bushes.
What's the story with a T6... Known suspension movement or abnormal?
Hi There
Bump this thread......did you ever find the issue I have a Multivan with DCC and have a similar problem......changed out the Drop links and the lower ball joints....still there....ordered poly bushes.......if that does not work then its the top steering bearing.........would not notice it on a smooth road but a rough road it shudders and gives feed back.....not bad but just a little annoying as a 2500kg vehicle should be smooooth!!!
