Sweet that’s not too bad, what springs would say are best? Keep on reading either H&R or cobra?Approx 3 hours labour so depends where you take it, anywhere form £75 to £150
Yeah I still am needing to find someone to carry out the work.. all I want is 30 or 40mm springs. So if you find a price please let me know mateWatching with Interest too, only want a 30mm drop myself.
Is it really as easy as YouTube shows? I’m far from stupid and have all the tools.. just need spring compressor. Part from that it’s sll fairly straight forward?Just did my own springs, rear is really easy and only 1hr using a jack, font are a little more difficult and you need a set of spring compressors to take the old springs off. I would say it took 1.5hrs each for the front, again on the jack. But make sure you allow for 4 wheel alignment after! That cost me £75 at ATS
Yep, really easy, if you undo the ARB bolts it is even easier on your own. I used Ebiach 30mm springs and I didn’t need a spring compressor to refit the new front springs. Make sure if watching you tube you are watch for a T6 as they are even easier than the older t5Is it really as easy as YouTube shows? I’m far from stupid and have all the tools.. just need spring compressor. Part from that it’s sll fairly straight forward?
No not on the T6, it just has 2 flanges that sandwich the cast hub assemblyDon’t you need to jack the strut out of the hub assembly like you had to on the T5? I bottled it when I did the T5 and got someone else to do it.
Good shout! Be careful and always use good quality spring compressors, and pout the spring away from you or your van! Watch for the spring compressors slipping round together and then having a spring like a banana which is dangerous to unload the compression!A word of warning if new to spring compressors, buy decent ones, work with it pointed away from the body, and PLEASE, don't look down on the compressed spring! There is a lot of force in them, even compressed "lightly"! They have been known to slip off, a danger if not used them before..![]()
