I've had my Eber for about 5 years from new and mounted underslung. I'm sure it has never performed correctly for long. It runs for a while then goes to "error". Sometimes I'll restart it after it cools down and it will then run ok. I don't use it very often but try to run it for exercise when I can.
I got it looked at at about a year old under warranty. I'm told no error codes showed, It was taken apart and run continuously on the bench, no problem.
Then continued doing the same error routine as before.
Then a year ago I took it somewhere else and paid a fortune for them to do and tell me the same thing. This time I got them to change the combo sensor as I'd read it was a common fault.
Then continued doing the same routine as before. Until now, it just runs for 20 minutes then gets error... repeat.
I'm totally fed up with it as Eber technicians are few and far between and every time it's not actually been fixed.
I should add it was professionally fitted in the first place.
