Lovebus WA
When you order the factory option of the second battery, where is it mounted in the van? Can’t find any info about it on the VW site.
Many thanks
Many thanks
When I looked (over a year ago) it was around £300 if I remember. Which was about the same as an aftermarket one with the same spec, but was going to be no use as a leisure battery. In the end I went for a Renogy LiFePO setup.Wonder what they charge for factory option battery
I note you're in Western Australia.When you order the factory option of the second battery, where is it mounted in the van? Can’t find any info about it on the VW site.
Many thanks
It’s $750 for a 75ah agm here in WAWonder what they charge for factory option battery
I have a Hanook 60ah AGM battery. It is 190mm high. It fits under the seat but with a vertical battery connector and a Kiravans seat swivel the connectors were too high and at risk of shorting to the swivel.Sorry to hijack this thread. Can you fit a xr1750 under the drivers seat. Thanks
Just interested....are you in UK...as my factory leisure battery charges to 12.8 to 12.9 volts from engine in Australia. which I consider full charge.I’ve got the factory leisure battery with a pair of BM2 battery monitors which have been fine for nearly 5 years.
Just be aware of the 80% limit on the leisure battery, so I always take my Ctek MXS 10 charger and I fitted a set of Ctek quick connect leads - CTEK 40-133 Start/Stop CT5 Indicator Eyelet M8 https://amzn.eu/d/040JQt1
It depends how long you want to go off-grid for I suppose, 2 days has always been enough for us with my Webasto heater, led interior lights and phone charging.
Thanks for that info... VW must change something for Australian vans, because my leisure battery rests at 12.8 volts (when not camping) even after extended time.Mine’s sat at around 12.3v over the last 15 days, it’s a UK van with the basic split/charge relay.
