Hi all, by way of update, VW main dealership had my van for 4 weeks in June to try to solve this window problem. As I said before the windows weren’t working when I dropped it off so they took it straight into the workshop for diagnostics. Unfortunately the VW procedure told them to stop and restart the engine, which always, at least temporarily, solves the issue. They then kept taking it out for drives trying to get it to fail again. Eventually this happened but the windows started working again before they could get it into the workshop so they couldn’t test but they concluded from this it could be a simple wiring issue. I doubted this, due to the fact the windows always start working again if engine restarted, but they fitted a parallel wire and unfortunately it made no difference. They therefore concluded it could be passenger side module (which I believe includes motor and control unit). They have already replaced the drivers side module a while ago and the drivers switch. Sadly, though, when I picked it up the windows failed again. First time, the passenger side wasnt working from either switch whilst the drivers side was still operating fine. The second time both windows stopped working but then started working again on their own having just been cruising down the motorway.
Given all VW have done they are really scratching their heads as to what could be causing this problem so if anyone has any ideas I’d be really grateful.
Thanks.
