Electric driver window is stuck open
Josh83abc
Hey guys! On my t6.1, the driver window is unresponsive (and left open). It has happend while I was using it. I has open it, so it went down, and right away, I tried to close it and it was unresponsive. The passenger window is fine. Interestingly, the confort open with the remote key doesnt do anything, even not the passenger window. Is there any fuse which is only for the driver window? I have the fusebox layout (from vip membership), but I dont see the electric window fuse. Which number it is? Thanks a lot!!
@Pauly any idea which fuse to check?
@Josh83abc can you hear anything when you operate the window switch? Can you assist the window by holding any visible glass (should be enough to get your fingers on) and pulling up while operating the switch? Sounds like the comfort setting imo.
Fuses 27 - 30 amp in the dash fusebox feed the door control modules (fuse 26 is the other side)
