Hi All,
For clarity i have scoured for threads already but can't 100% find the answer i'm looking for.
Setup:
EHU from bonnet runs under driver and to rear of van where the breaker & charger units will go.
Leisure battery on passenger side, fused & run to drivers side where i plan to put the inverter 300W(cont) Photonic Universe. the inverter has an earth nut.
Also on the drivers side will be the heater pipe coming up through the floor and out the back panel of the seat.
Ideally i'd like to plumb the inverter into the mains line i've already run to the rear using a crossover switch.
From what i can find, i believe i need to do the following:
Put a plug with and RCD from the inverter to the switch
split the line and put the crossover switch between the two.
What i can't find any real confirmation on is whether the inverter needs to be grounded?
WHen on the EHU switch the breaker will be earthed to the chassis and to the EHU ground spike outside.
But when inverter is selected surely this would also be grounded via the breaker?
Also is there going to be some serious heat issues with this and the victron MPPT being in the same bay as the outlet? I Guess i could insulate it to reduce a build up.
Worst case i'll just run the inverter floating but then i've got another socket and i wanted to try and keep everything neat and tidy.
Looking at @Deaky @Dellmassive etc.
Thanks in Advance.
Setup:
Thanks in Advance.
