Evening all, can anyone tell me what socket I need for the driveshaft retaining nut on my T6?
It's a 12 point socket but unsure of size.
Cheers in advance .
Off the top of my head I think its about 32mm.
The manual only gives the torque. 200nm back off 180deg 200nm again. Do you have a torque wrench that goes to 200nm.
also manual stresses that you must not undo that nut more then 90deg with the van on the ground.
I have a metrinch socket that is marked 31/32mm that fits but I 'modified' it to fit something else (I can't remember what now, might be the hubs on the Caterham) which I used to get them off but I needed an assistant to press the socket onto the hub while I levered on the breaker bar. I'd like to add a proper sized socket to my toolbox to tighten them back up again.
So 30mm 12 point socket from B&Q it is then, let's see if there's one nearby..
