Drawbar Between T5 And T6
Johnk
Lads, quick stupid question...
are the mounts for fitting a drawbar to a T5 and T6 the same? As in could you fit a drawbar from say 08 to a 15 van? Cheers
By Drawbar, do you mean tow bar?
The mounting points for the tow bars has not changed but the newer T6 vans seem higher than the original T5 so ball heights may have changed, mine is really high, a removable Westfalia about 2” higher than it should be.
Yes apologies call it drawbar in Ireland, got an older one and was going to fit on a newer van if it was a runner. Cheers for the help man, much appreciated!!
