Door card, Pillars and headliner trim
I think this is the route am going to go down for the lower plastics. Use my van as a daily so it gets mucky pretty easily with being in and out of it with work and what not. Don’t want to spend a fortune and material just to scuff it.
I saw on a T4 forum that one member used buzzweld pio black spray. So ordered some along with some Upol primer. Will spray spare door cards first and see what it ends up like. Thinking of trimming the inner panel with the GTI material to match seats too. Apparently the paint is very tough, and easy to apply when prepped. Will still be trimming headliner and pillars nearer the windows .
Done a cracking job on them.
I used Buzzweld PIO and it states to not use a primer but it marked straight away. For the money it was very poor.
Im half tempted to go down the raptor (done on fine) route as you can get it in any RAL
So finally got round to spraying the door cards this weekend. Wash a couple of times, rubbed down with scotch bright to get the shine off. Then I ran a blow torch over the doors, apparently it changes the molecules in the PP Plastic to allow paint to adhere. ( not sure if true but saw it and thought why not)
I then primed them with UPOL Plast 2. Then give them 4 light coated of Buzzweld Pio. Paint went on really well. Then a few Coates of clear Laquer. Really happy with them. Time will tell how they get on with scuffing and what not.
Decided to paint inners too so really didn’t need to take apart. But will be putting suede on the ones coming off van so good practice.
I now have a Caravelle, the roof vents and switches are cream/white. Has anyone painted these, or what do people do with them if they have a suede roof lining?
Like this? Details in my build thread :thumbsup:
Hi Daubhaus. Can’t seem to find this on your build thread. Do you have a link?
Wanting to do my headliner but no idea what to do with the cream panels!
Hi bud, I used Audi Headliner Material from FabricUK, but looks like they don't sell it anymore! My fabric failed after 12 months, backing foam separated from the front fabric. >> Here << I've since re-covered in woven nylon with a 2mm scrim foam backing from Martrim >> Here << and it looked pretty good. I've had a replacement cab headliner recovered in Dinamica by Steve at Edge Automotive . Have to say having it done professionally does look loads better. Getting the fabric to flow round the contours of the centre console in the headliner is not an easy task without too much stretch on the fabric. Check out >> Here <<
Any update on this? Looking to do mine at some point but not sure how well the spray paint would hold up?
Hi pal.
They have been absolutely spot on. Have had no problems at all, use my van as a daily so in and out all the time. They’ve held up really really well.
Great, I think this is the way forward then. I’ve have done the headliner and trims and they look great. But just makes all the other grey look worse now!
They look spot on, mate has black OEM ones and can hardly tell difference. What did you trim your headliner and pillars with?
I do have another set of door cards so going to trim them and see how they turn out.
