Have been out of stock for weeks, I’ll have a look at the Hilti ones. I like to stick with what I know works but…Screwfix or Toolstation may have a similar fixings.
Going onto a painted wall so only as good as the paint. Not scraping it off.I find with dot and dab walls no matter how light weight whatever it is you are fixing you need to use a massive fixing to get it to hold (using anything smaller normally backfires), these fixings look great for heavy duty applications but at 10cm long not really a solution to this problem. What’s the light duty solution for d&d walls?
Tile board onto a badly painted, skim plastered, very light concrete block wall - so light the previous attempts by somebody to screw into the block has cracked the blocks. I know the dewalt anchors work well and I have lots to do.What you hanging?
I use Corefix for dot & dab walls.
No plasterboard, don’t go much on those Fischer self screwing jobs. It’s about 2mm of plaster on aerated (chocolate) blocks.The OP @DXX was asking about
"for lightweight block, 50mm long. " - Not dot n dab.
Though I think the post originally said airated cement block .
Can be a tricky situation to fix to depending on how big the war the void is behind the plaster board.
I would normally use a corke screw fixing (some people call them Christmas trees)
Or if it was something heavy duty, then as above I'd use a huge fixing that goes right through into the wall behind, but make sure not to screw the fixing up too tight to then crush the plasterboard.
That maybe the solution, have you used them before?
Yes. They are good. I've always managed to create a chasm using the metal screw in fixings.That maybe the solution, have you used them before?
Yep, they took my £ and never had them in stock, got a refund after 3 weeks.@DXX![]()
Dewalt Aircrete Anchors | 50Mm | Box 50 DFM3450100
Removable Tension-Free Fastening For Aerated Concrete Block. Approved By Thermalite. Spiral Threads Cut A Positive Fit Into The Block With No Spalli...www.powertoolsdirect.com
Their probably available elsewhereYep, they took my £ and never had them in stock, got a refund after 3 weeks.
I’ve trawled Google for a month, everywhere is out of stock. Even the Black & Decker Dewalt Customer Support don’t know when they will be available.Their probably available elsewhere
Tried them, OK as long as more than 2” from the edge of a block otherwise the block splits. As I can’t see the blocks as skimmed over it’s a no go.
