Dead battery - cannot open doors t6.1
Pallet pump truck with the forks either side of the front wheel tyre, like how they lift cars overstaying on a meter?
That's not a bad shout.
I said to buy one of those all bag pumps, hire a compressor and put it under front wheel, lifting one side at a time. Get it on bricks on levels then get to the starter.
A T5 2007 you say?....
Has that had a T6.1 facelift then?
Does it's run on the T5 engine, and BCM?
One of these.....
And one of these..
Around £100 delivered for both.
Not sure, although he's changing the engine for an amg engine this year as far as im aware.
It's a twin slider T5. He has changed a lot. T6 dash and electrics, t6.1 front/rear. It's had a lot of money spent
One of these.....
And one of these..
Yeah that's what I originally thought. Get it under each wheel.
Ill send him them, thank you, you're a star
Good luck with that....
Fyi the doors will be auto deadlocked, so the internal pull handle won't work.
But the key should 100% work in the door even when it's deadlocked, assuming is standard and not been messed with.
Also when you get it sorted it recommend a Anderson, Ctek. Victron quick connect wired to the battery and cable tied down under the rad area...... So you can connect a charger in future.
Add a monitor....
Get a jump pack . . . .
He's bought this (wether it's any good or not?)
I'm leaving mine at 9am for the 2 hour drive to him, hopefully I have some good news later
I assume he has tried the key in all the doors with locks including tailgate etc.?
Yeah so far he's tried
Key in all doors
Gaffer tape on window in a square to pull down
Putting power to fog light and horn
Nothing has worked.
I did say try get under the back to power the compressor up. Atleast if it lifts, can get a jack under.
The doors have most likely been replaced and lock barrels not been changed that’s why the key will not work.
A lock smith may be able to pick the lock.
As someone suggested earlier, dig down under a wheel or under a sill and get a low profile jack then get access to the starter and attach jump leads.
