CXEB Excessive oil consumption, possible solution?
Getting in will be tight, be careful that the rear edge of the head is tapered or you might end up chopping it and spitting it into the turbo’ / DPF if it doesn't come out
I’d practice with a dummy hole…..but that’s another forum.
If the bores are worn an oil analysis will highlight it for £45 and no spanner work. The iron and soot levels will be very high.
