Hi Marc
So to get the very best. From the CP3 pump upgrade you should really have the following in place.
1) Strong base engine with good even compression across all cylinders.
2) A large FMIC I use a Wagner stage 1
3) Decat and large bore single box exhuast
4) Hybrid turbo. 360 race thrust bearings. 68mm billet turbine with exhaust matched to match. Cross exhuast chamber balance valve machined and ported.
5) A good's strong clutch .
6) CP3 Bosch R70 HPHV fuel pump plus an uprated fuel rail pressure switch.
You will definitely need to get a new nap as the turbo and fuel pump will be working way outside the factory spec and as such your nap just won’t know what to do to get the very best from your mods.
Turbo
Darkside 62mm Hybrid Turbocharger Unit for VW Transporter CFCA 2.0 Bi-TDI Engines
www.darksidedevelopments.co.uk
CP3 pump plus fitting kit.
Stage 1 CP3 Fuel Pump Conversion Kit for VAG Mk6 Platform 2.0 TDI Common Rail Engines
Fuel rail pressure switch
This Sensor will allow your highly tuned CR Engine to measure rail pressures up to 2700bar. Stock sensors are usually 2000 BAR
