Starting to think I shouldn’t touch electrics ever again…
I’ve just removed the headlining in the rear of my LWB van as I’m sound deadening the roof. The lining has already been covered and has some speakers in the roof. In taking it down (on my own) I got a bit stuck as it’s large and heavier than normal with the speakers fitted.
The courtesy light cable in the back was under tension for a while and then popped off. I disconnect the speakers and those cables seem fine.
Now the courtesy lights (back, middle and front) won’t switch on and the hazard button is illuminated. Any ideas? Could it be a fuse? If so where is it located?
Thanks in advance!
Thanks in advance!
