Has anybody with a T6.1 with rear heating option had there van rear carpet lined , not sure of the options because of the additional panel covering the rear heater
You could get the fins of the vent (or the whole panel) flocked to match the carpet if you really dislike the plastic showing through.
After a recommendation from someone on here, I used Flocking Fantastic for a different panel and they were great.
You can use carpet lining but depending on how fitted might make the panel tight to attach remove etc. You can use a thinner materia such as suede/Alcantara, Milano etc. This also gives a nice contrast against the carpet lining.
