Carista acc not available
marsie
Sold up
Hi, yesterday I got acc not available and front assist not available when I started my van. This also resulted in no cruise control
My carista didn't list any faults (not to do with acc anyway!) But I did find the square box on the bumper loose (appeared to have popped of a balljoint) so I refixed it thinking that was the cause but still unavailable?
I am guessing that because it came off its mount that it threw a wobbly and shut down but is there a way to clear a fault with carista, if so where?
Paul
So after all Carista listed some faults?
Please post "Detailed ECU info"-report (under Carista Service menu)
ECU info obtained with Carista 6.3.2 for Android:
Code:
VIN: WV1ZZZ7HZHH170414
Engine
Part #: 04L906056KN
Component: R4 2.0l BTD
Software version: 3776
ASAM/ODX identifier: EV_ECM20BTD03004L906056KN
Coding: 00254014436701080000 (hex)
Fault codes:
25796 Manufacturer-specific code
15560 Manufacturer-specific code
Transmission
Part #: 0BT300012C
Component: DSG DQ500-7A
Software version: 5302
ASAM/ODX identifier: EV_TCMDQ500021
Coding: 0014 (hex)
[No fault codes]
ABS
Part #: 7E0907379Q
Component: ESC
Software version: 0133
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 517EC0986569847E8A790377A68621A679F700 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
Software version: 1107
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 440F010300 (hex)
[No fault codes]
Airbags
Part #: 7E0959655G
Component: VW10Airbag021
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 000000000000000000000000000000003231 (hex)
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Headlight aiming
Part #: 6R0907357C
Component: AFS-ECU
Software version: 0050
ASAM/ODX identifier: EV_HeadlRegulVWLWRCC
Coding: 0FCE020001000000 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475AA
Component: PARKHILFE 8K
Software version: 0212
ASAM/ODX identifier: EV_VW75XParkAssis8K
Coding: 30810C (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907047AK
Component: Climatic-T5
Software version: 0708
ASAM/ODX identifier: EV_ClimaticT5
Coding: 0000000003 (hex)
[No fault codes]
Trailer
Part #: 1K0907383F
Component: Anhaenger
Software version: 0100
ASAM/ODX identifier: [none]
Coding: 0100000000000000 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090B
Component: BCM PQ25 Max4
Software version: 0744
Coding: A0AC393A0A61341193284F606CEB9F74C084738960CD79603204003F0860 (hex)
[No fault codes]
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042307 (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
All-wheel-drive system
Part #: 0AY907554L
Component: Haldex4Motion
Software version: 7620
ASAM/ODX identifier: EV_AllWheelContrHA1VW37X
Coding: 0505 (hex)
[No fault codes]
Adaptive cruise control
Part #: 7N0907572C
Component: ACC Bosch PQx
Software version: 0211
ASAM/ODX identifier: EV_ACCBEGVW361
Coding: 00005000FE0779 (hex)
Fault codes:
01540 Headlights are being lowered
01541 Headlights are being raised
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B1A73 (hex)
Fault codes:
02252 Generator
Infotainment system
Part #: 5C0035680E
Component: MU-S-ND-ER
Software version: 0363
ASAM/ODX identifier: EV_MUStd4CTSAT
Coding: 065700013C00000011111101008808001F0100D6002001004F (hex)
[No fault codes]
Unfortunately Carista strangely pads the fault codes by leading zeros. In that module those are actually
1540 - Sensor for Automatic Distance Regulation; Incorrectly Positioned - C1103 00 [009] - - - [FAULT_MISALIGNMENT_HORIZONTAL]
1541 - Sensor for Automatic Distance Regulation; Incorrectly Positioned - C1103 00 [008] - - - [FAULT_MISALIGNMENT_VERTICAL]
One of the ball joints had popped off so just pushed it back on. Looks straight now but still no acc
You would need to reset misalignment fault via BASIC SETTINGS reset procedure.
See below.
Well, the plot thickens!! On my way to Dav-tec tonight and the ACC suddenly started working again:rolleyes::rolleyes:. Anyway, got all the faults cleared (apart from a stop=start fault) and the app-connect switched on:cool:. Chris is also doing me a Nav update which will be ready tomorrow:D
Reactions: mmi
The Stop/Start fault most likely relates to the codes 25796 and 02252 - no communication to the alternator.
For more look here:
Thanks mmi, my van has a split charge set up fitted so I am going to disconnect that before delving any deeper. If the fault persists I will dig into it further. Not particularly bothered about the stop start working but I want to know its charging as it should
Reactions: mmi
