Wanted Car play
Tbomb
Hi all,
I’m after a 5Q0035726E core to allow Apple car play on the van.
Looking on places like amazon & eBay, a lot of them are 2-3 weeks lead time.
As you can probably tell I’m impatient 🤣
Posting on the off chance someone may have one they could sell me?
Thanks in advance
If you a SD slot, you can install via that, i got in touch with east yorkshire retro fit, send the a photo of you head unit and serial number, they'll send you SD card with install instructions. Worked a treat on my T6 iirc it was £90
Thanks mate I’ve emailed them asking if they can help 🤙🏼
The part your after is very common and readily available from various places, a genuine part is only around £20-30 from VW and things are generally next day with them.
Have you checked your existing unit to see if it has a green plug on the back ?
My existing unit is purple, do i have to get a wiring loom too?
There are different modules with different connectors depending on if the van has single or dual outlets, as long as you get the correct type it’s just a straight swap of the outlet for the same type with green plug
