So the van gets converted in Feb and the package I've gone for includes these electrical things:
I'd like to use the camper in off-grid/wild camping scenarios which would last around a week. A solar panel seems to be another sensible option for an upgrade but don't know if the Sargent ec155 deals with that side of things or if I need something better. I read somewhere on here that the Sargent units were no good for split charging the leasure battery. If that's the case what would you advise me to upgrade to? Do I even need an upgrade?
I'd really welcome members advice on what they'd do in my position. I obviously need to get this right at the beginning of the conversion rather than getting things upgraded later on.
- Exide es900 900wh gel battery
- Durite 0-727-33 12 volt 140 amp charge relay
- 20 amp circuit breaker
- 15 amp wurth fuse holder
- 12 volt relay
- 18 metres black flexible conduit
- 19 metres 6.0mm bs6231 red tri rated cable
- 4 metres .75mm bs6231 red tri rated cable
- 1 metre .75mm bs6231 green tri rated cable
- Sargent ec155 power supply unit ec50 control panel 240 volt and 12 volt harness
- 240 volt hook point
- 2 x 3 pin slimline power points
- 12 volt charge socket
- 6 x flush round led lights
- Flush round bed light
- Lab craft nebula strip light
- Waeco cr50 compressor fridge
- Carbon monoxide alarm
- Under seat battery bracket
- Lots and lots of terminal connector and cable ties
