Can I replace my 17’s with 16’s?
exstuntwoman
My 2020 T6.1 came with 17inch rims ...I want to go to 16 inches as I like rims better...see pic attached...will there be any problems in doing that? Or is it an easy swap?
If your van has the bigger brakes I don't think 16's will go over them. Other than that they should swap straight over. Is your van a T32, 30 or 28?
or safer still, upload a photo of your front brake caliper.
PS are you sure you have a MY2020 T6.1?
Probably doesn't make much difference to your question, but that looks more like a 5.1...
But anyhoo, why not go 17" rims, that way you can use the same tyres?
I think the picture is just an example of the look they're after?
Just my take on it, could be wrong.
But in answer to the question, as said above it will all depend on front brake size.
